Good progress today (1hr in the morning and 1 hr after work). I finished up the filter line that runs from the fuel valve to the filter. Tricky with the tight bends but it turned out good. I then fabricated the feed and return lines that run through the left gear tower. They have to be made in place as the B nut won't fit through the gear tower holes so it's a little tricky. Good progress and everything is snugged (not torqued yet) will the final feed line running from the pump assembly to the firewall yet to be done.
Flaring in the close quarters of the side console was tricky but doable without removing components.
Filter and the bottom of the fuel selector valve T fitting visible.
Lines coming thru the gear tower and into the pump assembly
