Brief Description: Fuel System install #3 (or #2 redo)
Well in trying to get the right tank fuel line to properly position along the front of the spar I found it need too much tweaking so I cut off the bends that I had put in it at the fuel selector and started over with a new flared end and new bends. The previous one was too close to the rudder cable for my taste. The new one is much improved and I am back to where I was. Next step is to bend the line where it exits the fuselage.
Here you can see the line fitted to the selector valve and loosely in position along the spar
