Brent s RV-8 Project N784DE
Date:  12-21-2009
Number of Hours:  1.10
Brief Description:  Fuselage wiring runs #3
Got several little things accomplished.
Finished pulling the battery cable conduit up through the rt gear tower.
Drilled the holes and installed grommets for the strobes wires (left and right)
Drilled hole for rear seat map light
Here's the batt cable conduit bunched up under the rt console prior to pulling it thru the gear tower
Back seat maplight
Back seat maplight
One of the strobe wire grommets near the bottom longeron
