Due to a myriad of personal and professional issues over the past couple of weeks I lost some valuable time on the aircraft. Once you haven't work on it for a couple of days, each day gets harder to get going. Only did a little today and since I'm not that found of putting material on and then sanding it back off - over and over I was even less motivated. Even so, I managed to mix up a medium size batch 48 grams of epoxy and a couple of small cups of mico to mix into a slurry for the canopy skirt I hacked up. -Went on pretty easy.
