-Layed out the hole pattern for the new skin rivets that will attach it to the doubler. -Drilled the holes fromt the previous step. -Layed out the doubler reinforcement rib holes that attach it to the doubler and drilled -Layed out the joggle for the baggage door - carefully... -Cut it out with the dremel and then used the pneumatic belt sander to get it on the line and then blocked it out with 180 grit - turned out good IMHO. -Cut thet baggage door aft rib to allow for the joggle. -Layed out the new hole locations for it. -Cut the doubler and fitted that runs under the baggage door hinge support -Drilled holes in the baggage door for the new aft rib location -Fabricated a stiffner that go across the baggge door below my new joggle and ties to the aft rib -Trimmed the back of the baggage door for the joggle -Layed out and drilled new holes for the understructure changes -Layed out the new stiffner holes in the bagg door and drilled I'm virtually done, just a little bit of fitment and I need to consult the plans and take the steps required for the hinge, latch, etc.
New skin drilled into place.
Door cut out successful. Me drilling the holes of the new stiffner
