Put the canopy back on the airplane. Cleco'd it back on and then riveted it on temporarily with pop rivets spec'd by the plans. That is nerve racking pulling those blind rivets into the plexiglass. Went well though.
Then I layed out and drilled the canopy skirt holes into the canopy frame per plans.
Here it is riveted on, cleco's are obviously still in place.
Here's the template I made per the plans used plexiglass instead of aluminum which worked good.
