Finished up the manual aileron trim this morning. -Installed the nutplates on the arm rest -Assembled the lever and cable to the main mounting bracket that attaches to the sidewall. -Trimmed the cable and sheath to the appropriate length. -Added the bend in the cable to keeps it attached to the lever. -Riveted the cable retention bracket to the support bracket -Attached the cable to the push/pull rod. Works good. I may have trimmed the sheath alittle short, but I'll teak on it after the controls are rigged up. Finished.
