Started on the manual aileron trim this morning. The instructions are more like the empennage to there is alot of head scratching as the text and drawings are iffy compared to the -1 fuselage kit. Luckily I installed the support bracket and the tube guide during the seat rib build up, but after looking at the directions, I wish I would have done more prior to this stage - oh well. -Finished fabricating the slide tube per the plans. -Deburred and primed the anchor bracket, the lever, the mount plate and the connector plate. -enlarged the SB437-4 snap bushing to 21/64 with the dremel and a burring bit. -Layed out the hole location and drilled a singel hole into the delrin friction block on the drill press -Attached a nutplate to the anchor bracket
