Only had a short time to work on this after getting the subpanel parts primed, but I took advantage of it by roughing out the bracket for the parking brake. This bracket will replace the one in the plans that transitions the flex brake lines to the hard lines above the rudder pedals.
Parking brake bracket held up into position on the bulkhead behind the instrument panel.
