Put the rudder pedal assembly together on the bench, hopefully for good. Had to file alittle here and there to get everything to work properly. The castle nuts are not torqued to allow freedom of movement between the parts. I put the whole thing in the fuselage and bolted it down. Then I installed the rear rudder pedals and hooked up all of the cables - looks cool.
