-Final drilled #12 (used 3/16 reamer) the rod end bearning holes in the WD807 control column -Final drilled #12 (used 3/16 reamer) the holes in the WD807 control column used to attach the aileron pushrod assemblies. -Removed the bushings from the front and rear sticks and filed them down with a sander to fit within the WD807 control column lengthwise. Lots of trial and error here. -Did the same with the control sticks (made them slightly shorter than the bearing (careful not to remove too much material here). -Reamed the bushings to accept the AN4 bolts (1/4") -Bolted the front stick to the control column
Control column and associated parts.
bearing and stick sanded down to fit within the WD807
