-Cut the 3 brackets that make up the bell crank out with bandsaw and then deburred the edges with the 3M wheel. Next I cleco'd the pieces together with the bearing and match drilled to #30. Then I disassembled, deburred, and scuffed those parts to be primed.
-Next I measured out the pushrod and cut it to length. Outta time - gotta go to work!
