-Dimpled #40 the bottom flange of F818A(L/R) that are common with the bottom skin. -Dimpled #19 the F824(L/R) aft side skins for the rudder cable exit guide clamp screws -Dimpled #6 the nutplates on the aft inspection cover on the F824(L/R) aft side skins along with the #40 nutplate holes. -Rolled the edges of the skins per the plans on page 8-32. I started using the roller vise grip tool and reverted to the flanging pliars as the roller was marking the skin up.
Dimpling the F818s
Using the roller to bend the edges of the fwd side skin per the plans (help the joints lay down nicer)
