-Cut the slot out of the middle left rear armrest for the rear seat throttle - turned out pretty good.
-Bent the mid fuselage side skin per the plans. It called for marking the skin at the bend line and then clamping a beveled 2x4 in place with the line matching up to the edge of the bench. Then I installed the angles on the outter edge for the sole purpose of twisting the skin to comform with the F-807 bulkhead. When pretty good, not perfect but the holes did line up adequately.
