-Reattached the center section to the fwd fuselage.
-Bent the center section side plates and the landing gear box plates per the plans and cleco'd them into position.
-Separated and deburred the upper and lower longeron gussets per the plans.
-Clamped the lower left longeron in place and match drilled per the plans. I then countersunk the 2 screw holes in the gear weldment and installed the bolts on the engine mount side of the longeron. Then I disassembled and deburred everything and reassembed.
-Ditto for the right side..
Good progress today 5.7 total.
Left lower longeron clamped into place and ready to drill.
Drilling the lower left longeron using the holes in the fwd floor.
