Worked on the pitot tube since I need to prime the bottom skins and it was raining and dark at 5am . I scuffed, cleaned, and primed the base of the pitot tube, the spacer, and mounting bracket. I then installed grommets in the left wing for the aluminum pitot line. I routed the tube around the aileron bellcrank to avoid interference. I need to add fittings and flare the ends, but otherwise it looks good.
Pitot tube componenents primed.
New hole for the grommet to route around the aileron bellcrank.
Here is the aluminum pitot tube line installed - small one.
