Finally made it back out to the shop after a pretty unproductive week (or two). I finished deburring the bottom outboard skin for the left wing. I also scuffed it on the bottom in preparation for priming. I like doing that before dimpling as the dimples destroy the scotchbrite pads I use to scratch the surface for priming. I then started on the bottom outboard skin for the right wing. I needed to remove the plastic from the bottom and top (I completely remove it from the bottom of the bottom skin vs cutting out the rivet lines on top.) I Then deburred the edges of that panel. I need to finish this skin and the left and right wing inboard skins (smaller) and then I can start dimpling holes, then clean, tape of the holes and prime. After primer we're riveting!
Deburring the rivet holes. (left outboard panel)
Removing plastic on the right outboard panel (top surface only)
Scuffing the bottom of the left outboard panel (bottom surface only top gets polished!)
