Brief Description: Flaps #11 (riveting the left flap)
I started assembling the left flap this morning - always exciting work. I cleco'd the flap together per the plans. I didn't use the wedge fixture and I didn't have any problems just shooting it on the bench. Everything worked out pretty good. I am about 3/4 of they way through and of course the last rivet I shoot into the root rib (rivet nut) the bucking bar slipped and dinged the web of the rib. I won't be too visible but it still sucks. Oh well, could have been worse! Overall, good progress and I should be able to finish it tomorrow and start on the right one.
406B (or is it 706A, the plans say both)
Skeleton cleco'd toghether - note the heater running! It was 20ish this morning.
Spacer that goes between the rear spar-thingy and the rib.
