Reorganized the garage to accomodate the wing stands. I moved my bikes into the garage at an angle and moved my work bench closer to the back wall. The stands will be 2' apart at the back and face opposite to each other. I called about renting a masonary drill and luckily enough I could buy one at Harbor Freight for what I could rent one ($27). I drilled my first hole after laying out the location of the wing stand bolt holes and it wasn't too bad. I had heard grumbling about this on the internet so I was kinda dreading it. I ran out of time, but hopefully next session I can get the rest of the holes drilled.
