Brief Description: Rib preparation #6 (holes for conduit)
Drilled all the main ribs for the wiring conduit this morning. 1st step was to cleco the jig to each rib and drill a pilot hole. Then I drilled out the hole with the unibit. Turned out good. Now I need to deburr these new holes and start the process of straightening the ribs.
Drilling a pilot hole for the conduit w/homemade jig and #30 drill bit.
Using the 3/4 uni-bit and my drill-press to make the final hole in each rib.
