Up this morning, removed protective plastic from the right elevator skin around the outer rivet line and finsihed deburring the skin. I then moved to dippling all of the understructure and the skins. Next step is scuff, clean, and then prime.
Removing plastic around the outer rivet lines on the right elevator
