Very cold in the garage this morning (25F) at 5:15am. Started riveting the top RH HS skin to the front spar (702) and center rib (708). Went well had to drill out one rivet - no biggee. Finished it up and I will flip it over and do the bottom skin tomorrow and then I will move back to the LH side to rivet the end and root ribs. These are along the edges so they will be squeezed rather than bucked - must faster and easier for me at this stage.
Riveting the front spar to the top skin of the RH Horizontal Stab
Some completed rivets from the inside - RH HS ourtboard of 708 center rib
Top skin completely riveted to the front spar and center rib - edges are next with the rear spar last
