Brief Description: Removed the skins and removed plastic from rivet l
In the shop at 5:10am this morning. Finished removing the skins from both LH & RH stabs. Then I worked on removing the plastic coating around the rivet lines using a soldering iron. Not as easy as it sounds. My looks kind of sloppy but it will do. Make sure your iron tip is very smooth or it WILL scratch your skins!
working the iron down my straight edge
Looks easy - it's not really took an hour to do the HS skins
Kinda sloppy but it'll do - the coating all comes off as soon as it is riveted anyway
