Brent s RV-8 Project N784DE
Date:  8-10-2011
Number of Hours:  1.80
Brief Description:  Much Misc prior to Inspection
Mostly housekeeping stuff for the FAA inspection for tomorow.
-Installed the spring on the inside canopy latch handle - sort of redundant...
-Tested the ELT
-Installed the CO2 detector - I cheaped out and used the $5 plastic disposable one.
-Installed the documents pouch with velco above the right aft arm rest.
-Tightened the intercom knobs down (pain)
-Put reflective aluminum tape on some of the EGT and CHT wires that pass by the exhaust pipes for added thermal protection. No safety issue, just don't want chared (read inop) wires...
Canopy latch return spring
Some alum tape over that EGT wire
Cheapo CO2 insight of the frontseater
