-Added a small heat shield to the exhaust to protect the aluminum drain line off the sniffle valve -Safetied the snorkel to throttlebody bolts -Screwed the snorkel to baffling bolts in -Installed the oil filter per the mfg procedures and safetied -Put in 6 qts of Aeroshell 100 -Installed screws into the left wingtip. Found one hole didn't have a nutplate - fixed that.
