Brief Description: Floorboard, wiring, F804 bulkhead covers, batt tie
Consistent with the theme of lots of little things getting done: -Had to removed the fwd floorboard cause I realized I didn't wire the rear 12v socket!! Duh! -Wired the rear socket -Resecured the fwd floorboard- lots of screws -Installed the F804 bulkhead covers with the specified blind rivets. -Secured the battery. Put a rubber booty on the positive terminal. -Vacuumed the rear tail cone -Put another cooregated plastic conduit on one of the rear wire runs that didn't already have one. -Started putting screws (lots of them) into the right wingtip. HOT - 97F I like it!
Under flor wireing and controls - all done!
Did I mention it was hot in the tailcone!
The righ side F804 riveted on. I moded mine with the ELT controller and a map/flood light.
