Brent s RV-8 Project N784DE
RV-8
Cowl heat shielding/rudder pedals/misc
Put the aluminum tape on the inside of the bottom cowl to reflect the heat from the exhaust and such.
Installed the rudder pedals and brake lines that connect to the parking brake valve.
Added a fuse to the HBB feed - didn't consider this for some reason during the original wiring. 30A blade fuse took care of this.
Aluminum material on the inside of the bottom cowl
Rudder pedals in.
Brake lines attached
RV-8 Home
2427
About me
BENCHMARKS
Elevators
Finishing
352
646
219
586
Hints and Tips
Horizontal Stab
Inspiration
Instrument Panel
polishing
post construction mx
PROGRESS CHARTS
Shop
Vertical Stabilizer
What is an RV8
407
Wiring
108
211
