Finished up the compound polishing of the control surfaces - elevators, ailerons, flaps, and root fairings today. Started cyclo polishing the last hour the vertical and horizontal stabilizers. Tomorrow will be a hard day of throwing the cyclo around on the fuselage the rest of the tail and all those control surfaces with F7 grit and then doing it all over again with S grit. Each area gets two rounds of each grade of polish so that's like polishing it 4 times - believe it or not, it still won't be flawless, but it should look passible, especial for the initial test flights. 8
