Started wet sanding the wing tips where I had filled some pin holes. Did the same with the wheel pants. First run of filler primer was applied to the top and bottom cowl Second run of filler primer added to the wing tips after fixing a couple of pin holes and low spot detected after the first run of filler primer. They are good to go now.
Round two. Still had several pin holes to fill-never ending.
Ready to have pin hole check done and touchup with the red stuff.
