Brief Description: Pin hole filling and sanding fiberglass
-Filled the pin holes that showed up after priming the wheel pants and spinner. Used a glazing putty (bondo brand). I then sanded the putty away with 600 grit wet. -Moved to sanding the epoxy glaze that was put on the cowling halves some weeks back. Did it with 400 wet, which works good, but it's hard to see the imperfections when the surface is wet. Did two iterations and we'll see how it looks. I will probably touch up the missed spots with 400 dry then soap and water clean and then filler prime.
