-Hit the fwd fuse on the right side with the cyclo and S and the S didn't get all the swirl out. I did 3 rounds on one section and it just wasn't to my, now reduced, standard. -Went back to the directions and it says I should probably use F7 (heavier grit) with the cyclo and then cyclo with S so I did the right and left side with F7. I won't know if it worked until I cyclo with S (final grit) tomorrow.
