Brief Description: Aft cockpit side panels and battery access
-Deburred the aft fuse side panels in preparation for priming. If it stops raining and I can get to NAPA for some 7220 I'll shoot these and some other parts piling up.
-Moved one of the rear headset jack plugs that was interfering with the aft baggage liner. -Marked the liner for trimming for the headset wires.
-Realized my hinged access panel for the aft fuselage caused the holes that keep it closed at the top to not line up (way off). I decided to take the hinge off for now and just unscrew it if I need to get back there, which now with the smoke system back there I shouldn't need to open this very often - remember I have the external access to fill the system. Plus I need to rivet the top brackets on and prime it. -Worked on installing the camloc latch for the battery access door that I built into the baggage floor.
I had to take the hinge off this door
battery access in the aft baggage compartment floor
