Brent s RV-8 Project N784DE
Date:  2-28-2011
Number of Hours:  1.20
Brief Description:  Panel 'eyebrow' LED / Tank Attach bracket
-Intended to use the warmer than normal weather (high 50s) this morning to attach my eyebrow LEDs (they need 60 degrees per the instruction or you could break them).
-While I was waiting for the heater to get the garage up to temp I put a new bandsaw blade on and read the instructions about the F-8-163 L(R) tank attach brackets that mount on the side of the fuselage. I want to cut those out so it's less work at the airport (you have to install them with the wings on).
Didn't start cutting metal before the temp came up so I put the LEDs in place - very easy and then routed the wire into the area behind the panel. Need to connect them to the dimmer pcb and then I'll be in good to go.
LEDs strip
LEDs strip
LEDs in place. Need to use something to seal the wire up into the corner so i't's tidy.
The tank attach bracket
