Brent s RV-8 Project N784DE
Date:  2-26-2011
Number of Hours:  2.70
Brief Description:  Wired E trim/12v socket/+
-Capped and secured the unused carb heat sensor wire and flap sensor wire from the EFIS.
-Wired up the E trim position sensor wires to the EFIS
-Wired up the 12v socket (front)
-Put the BNC connectors on the capacitence probe wires and routed them into the wing root, including exit holes and grommets in the fuselage.
-Installed the 12v front cig lighter socket
-Installed the aux audio in socket.
Messy! Wiring up the e trim and 12v socket (inside the tower) Once that is done I can bundle this mess
Coiled and tie wrapped unused audio panel wire (incase I upgrade some day).
Capacitence probe BNC connector , resting on top of the fuel line.
