Brief Description: Adel Clamping bliss/Engine Controls final
-Put a couple more adel clamps on to support the MAP line and the throttle cable. -Replaced temporary fasteners on the throttle with the correct length. Safety the mounting bracket, checked torque on the cable stays and rod ends and marked with torque lock. Put in the cotter pin on the AN3 bolt to call it done. -Started on the mixutre assembly when I ran out of time.
Fun with Adels
Throttle assembly - dun!
Safetied the 2 screws going into the bottom of the sump
