-Not much real work done on this session. I spent most of my time figuring out that I couldn't fabricate a hard brake line that would connect the grove gear to the bulkhead AN4 brake line fitting coming out of the bottom of the fuselage. There is no room to bend a curved or looped line to connect the two so I'm going to get a ss flex line to put in there and hopefully that'll do the trick. If I would have put a 90 fitting on when I installed the gear I would have been better off, but I think I'll be ok.
