-Sanded and recoated the areas on the cowling I had filled yesterday. Then just did some random stuff: -Retorqued the upper right engine mount to firewall nut after installing the ground strap. Re-cotter pinned. -Riveted the lower front corner rivets on the top fuse skin near the engine mounts. Used the no-hole yoke on it - worked great.
Retorqued eng mt bolt. Lowest rivet on the gray skin was installed too.
