There are cover plates that cover up the gear attach hardware under the fuselage. -I reversed mine to allow the fuel vent line that exits the cover to run in a more logical route through the tops of the gear towers vs going through a lightning hole in the tower. -Trimmed the covers to fit and drilled/deburred/dimpled for #6 screws. -Added a grommet for the vent line exit hole. -Bent and trimmed the vent lines to size.
Installed the landing gear leg upper intersection fairings. After they were screwed on I can see I need to do some more 'tweaking' but they are ok for now.
