Had to interrupt the cabin heat install to secure the part of the baffling that wraps around the cylinders. After alittle learning curve it went pretty smooth. I have about :30 more to do on this.
Note the safety wire. That goes inside the plastic tubing and pulls the cylinder wraps down tight
The big tube is an oil line. The tube with safety wire in the background is it.
Both the heads and the cylinders get this treatment
