-Bonded the upper cowl inlet ramps in place. -Finished drilling the airseal material to the baffling -Installed airseal onto the right inlet ramp - unfortunatley I screw'd up and my holes moved into the edge - I like fitting it to the cowl better anyway like the left side. -Fitted the airseal to the left inlet. Fab'd a reinforcement/backing strip of .020 to help reinforce the rivets. -Did some fitting of the cowl - need to work on getting the airseal some 'memory' so it lays down properly. -
