Lost a couple of days going out to Missouri to pick up a baby horse - it was worth it and honestly I needed the break from building. Today was light, but I did make progress. -Re-fiberglassed the snorkel and attached to the engine so there is no change it won't fit once it dries. I put mylar around the starter motor and alternator. -Put the bottom cowl on and fitted the inlet ramp to baffle side brackets. Match drilled the right side. -Located the center baffle (behind the spinner). Drilled the two small brackets that are on an angle. Still trying to figure out how to attach the rear brackets (not enough room behind the spinner). I may have to modify the supplied brackets
Snorkel on
Right inlet ramp to side baffle bracket located and drilled
