-Blocked off the inside of the snorkel so I could put in expanding foam for reglassing. -Sprayed in the foam
-Re-made the alum angle for the back of the inlet ramp -Drilled to match the ramp -Deburred and c/s -Rivetedd to the ramp. It is a combination of flush and std rivets due to the filter retainer brackets overlap
Limiting the are of where the expanding foam will go with gorilla tape
