-Finished the spinner, well except for the 'body work' part of it. -Fabricated the part of the gap filler that screws to the spinner rather than rivets to the backplate -Deburred all the parts for the gap filler -Rvieted the tab on to the gap filler (the one that screws to the spinner -Riveted the nutplate onto those (one on each side) -Primed both of them -Riveted them to the backplate (had to removed the backplate from the hub so I had room for the rivet squeezer -Put the backplate back onto the hub -Put the spinnner on to test fit everything - good to go
