-Riveted the fuselage hinges minus the upper hinges. -Put the cowling back on - had to work the pins alittle to get everything together, but I'm learning and it's getting easier. I'm not regretting the hinges - yet. -I then marked off areas that need trimming and areas that need glass or filler added. -Then I cut out a pattern for a cover that will hide the hinge pin retainer for the two horizontal hinge pins that bisect the cowl.
Installing the hinges on the airframe
Cardboard pattern for a cover that I'll use to hide the hinge retainers
