-Did some additional trimming to the lower cowling -Drilled #30 the holes that will eventually hold 3 screws on each side of the spinner inside the intake (attacheds the top and bottom cowl at the spinner. This was done with the two cowls mated on the ground -Put the top cowl in place and spaced it on the spinner with 1/4" of clearance and marked it for trimming to the firewall. -Trimmed the aft end of the top cowl -Cut the hinges sections for the top cowl at the firewall
Cowling fun.....the color of peptal bismal is appropriate
Drilled the screw holes behind the spinner (cleco's)
