Figured out a location for the filter, pump and flow control valve just fwd of the strobe power pack mounted in the same fashion between the lower and middle longeron (left side of the a/c). I fabricated the angled that will mount to the longerons, drilled the appropriate holes. Fabricated the plate that will serve as the mounting surface for the components. Drilled the holes in the plate and angles for the nutplates
Mounting plate and angles
Here you can see the angles in place between the lower and middle longerons
