Figuired out where to run the smoke oil line. Then I drilled and deburred the grommet holes through all the bulkhead between the smoke tank location (aft of aft bagg compartment) all the way to the firewall.
The lower black hose is the smoke oil line
Continues to travel through the spar and through the left gear tower
Here's the fuel pump that will do the job of moving the smoke oil
