Brief Description: install fuel tank & pull down L.E. skin
put the fuel tank back into the cavity for the final time. connected ground wire and fished fuel level signal wire out through end of nose ribs. connected fuel line to end of rank. placed straps around wing to pull down L.E. skin. I have wooden blocks along trailing edge to prevent straps from smashing skin overlaps i uses a long 1x2 on LE skin to spread out force of straps. straps are only placed directly on top of ribs to prevent deforming the trailing edge
