Brief Description: Fibreglassing cowling and baffles.
Picke dup the paint and painted the inside bottom canopy skirts. I then pulle dout the drawings and went over the baffling. I finally remembered why I stoppe dthe first time, I need the cowling fitted. So I started fitting the cowling. Cut and drilled the piano hinge and then cut and shaped the top cowling to fit. HAd to rig a temporay packer for the spinner base to get it all to sit OK.
