Brief Description: Started some fibreglassing of the tips
Continued fitting the tips to the elevators and rudder. Tried my hand at fibreglassing for the first time. See how it turns out in the morning. Set up the forward section so I can do some riveting on the forward top skin. Drilled out he hole for the rear strobe light. Think I am missing a wire or two. Will run a couple tomorrow to join up with the wing wiring.
VS tip with first layer of glass on
Riveted the top of the rudeder tip
Fitted and drilled the bottom fairing on the rudder
